Product Overview The Agilent N2X is the industry’s most comprehensive test solution for testing the development and deployment of network services for converging network infrastructures. Service providers, network equipment manufacturers (NEMs), and component manufacturers can verify service attributes of entire networks end-to-end, while also isolating problems down to individual networking devices and subsystems. Agilent N2X delivers unparalleled test realism to verify the ultimate performance, scalability and resilience of carrier grade services and infrastructure. The Agilent N2X Next Generation Ethernet Test Cards are available with 10/100/1000 BASE T and 1000 BASE-X interfaces including dual mode RJ-45/SFP. In conjunction with N2X Packets & Protocols Application they provide multi-port traffic generation, scalable protocol emulation and unprecedented performance analysis of today’s Ethernet networks and devices. From wire-speed traffic generation and analysis to full emulation of Internet-scale routing topologies using the latest protocols and technologies, Agilent provides the most flexible, comprehensive and easy to use system available today. These next generation Ethernet test cards are designed to increase test coverage and reduce test cost. Each port has a dedicated CPU and RAM – no sharing of CPUs and no compromise in performance. Next generation Ethernet Test Cards support an individual user per port. Multiple users can concurrently utilize their own test port maximizing the use of test equipment and return on year investment.
