CY74FCT16373CT,pdf(16-Bit Latc
消耗积分:2 | 格式:rar | 大小:319 | 2010-07-30
哈哈哈
分享资料个
CY74FCT16373T and CY74FCT162373T are 16-bit D-type latches designed for use in bus applications requiring high speed and low power. These devices can be used as two independent 8-bit latches or as a single 16-bit latch by connecting the Output Enable (OE\) and Latch (LE) inputs. Flow-through pinout and small shrink packaging aid in simplifying board layout.
This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
The CY74FCT16373T is ideally suited for driving high-capacitance loads and low-impedance backplanes.
The CY74FCT162373T has 24-mA balanced output drivers with current limiting resistors in the outputs.
评论(0)
发评论
下载排行榜
