SN74ALS990,pdf(8-Bit D-Type Tr
消耗积分:2 | 格式:rar | 大小:437 | 2010-07-30
分享资料个
This 8-bit latch is designed specifically for storing the contents of the input data bus and providing the capability of reading back the stored data onto the input data bus.
The eight latches are transparent D-type latches. While the latch-enable (LE) input is high, the Q outputs follow the data (D) inputs.
Read back is provided through the output-enable () input. When  is taken low, the data present at the output of the data latches is allowed to pass back onto the input data bus. When  is taken high, the output of the data latches is isolated from the D inputs.  does not affect the internal operation of the latches; however, precautions should be taken not to create a bus conflict.
评论(0)
发评论
下载排行榜
