The ’HC7266 contains four independent Exclusive NOR gates in one package. They provide the system designer with a means for implementation of the EXCLUSIVE NOR function.
This device is functionally the same as the TTL226. They differ in that the ’HC7266 has active high and low outputs whereas the 226 has open collector outputs.
