SN74LV86A-Q1,pdf(Quadruple 2-I
消耗积分:3 | 格式:rar | 大小:138 | 2010-08-05
李鸿洋
分享资料个
The SN74LV86A is a quadruple 2-input exclusive-OR gate designed for 2-V to 5.5-V VCC operation.
This device contains four independent 2-input exclusive-OR gates. It performs the Boolean function
Y = A B or Y = AB + AB in positive logic.
A common application is as a true/complement element. If one of the inputs is low, the other input is reproduced in true form at the output. If one of the inputs is high, the signal on the other input is reproduced inverted at the output.
评论(0)
发评论
下载排行榜
