MAX5888 pdf,MAX5888 datasheet
消耗积分:5 | 格式:rar | 大小:888 | 2008-09-11
分享资料个
The MAX5888 is an advanced, 16-bit, 500Msps digitalto-
analog converter (DAC) designed to meet the
demanding performance requirements of signal synthesis
applications found in wireless base stations and
other communications applications. Operating from a
single 3.3V supply, this DAC offers exceptional dynamic
performance such as 76dBc spurious-free dynamic
range (SFDR) at fOUT = 40MHz. The DAC supports
update rates of 500Msps and a power dissipation of
only 250mW.
The MAX5888 utilizes a current-steering architecture,
which supports a full-scale output current range of 2mA
to 20mA, and allows a differential output voltage swing
between 0.1VP-P and 1VP-P.
The MAX5888 features an integrated 1.2V bandgap reference
and control amplifier to ensure high accuracy
and low noise performance. Additionally, a separate
reference input pin enables the user to apply an external
reference source for optimum flexibility and to
improve gain accuracy.
The digital and clock inputs of the MAX5888 are
designed for differential low-voltage differential signal
(LVDS)-compatible voltage levels. The MAX5888 is
available in a 68-lead QFN package with an exposed
paddle (EP) and is specified for the extended industrial
temperature range (-40°C to +85°C).
Refer to the MAX5887 and MAX5886 data sheets for
pin-compatible 14- and 12-bit versions of the MAX5888.
Applications
Base Stations: Single-/Multicarrier UMTS,
CDMA, GSM
Communications: LMDS, MMDS, Point-to-Point
Microwave
Digital Signal Synthesis
Automated Test Equipment (ATE)
Instrumentation
评论(1)
发评论
wgy10086 2011-07-20
0 回复 举报
hhhhhhhhhhhhhhhhhhh 收起回复
下载排行榜
全部1条评论
