ADS831
消耗积分:5 | 格式:rar | 大小:406 | 2010-08-16
名士流
分享资料个
The ADS831 is a pipeline, CMOS Analog-to-Digital (A/D) converter
that operates from a single +5V power supply. This converter
provides excellent performance with a single-ended input
and can be operated with a differential input
for added spurious performance. This high performance converter
includes an 8-bit quantizer, high bandwidth
track/hold, and a high accuracy internal reference. It also allows for
the user to disable the internal reference and utilize external
references. This external reference option provides excellent gain
and offset matching when used in multi-channel applications or in
applications where DC full scale range adjustment is required.
The ADS831 employs digital error correction techniques to provide
excellent differential linearity for demanding imaging applications.
Its low distortion and high SNR give the extra margin
needed for medical imaging, communications, video, and test
instrumentation.
评论(0)
发评论
下载排行榜
