SN74ACT3622,pdf(256 X 36 X 2 C
消耗积分:3 | 格式:rar | 大小:507 | 2010-08-19
分享资料个
The SN74ACT3622 is a high-speed, low-power CMOS clocked bidirectional FIFO memory. It supports clock frequencies up to 67 MHz with read access times of 11 ns. Two independent 256 × 36 dual-port SRAM FIFOs on the chip buffer data in opposite directions. Each FIFO has flags to indicate empty and full conditions and two programmable flags almost full (AF\) and almost empty (AE\) to indicate when a selected number of words is stored in memory. Communication between each port can bypass the FIFOs via two 36-bit mailbox registers. Each mailbox register has a flag to signal when new mail has been stored. Two or more devices can be used in parallel to create wider datapaths.
The SN74ACT3622 is a clocked FIFO, which means each port employs a synchronous interface.
评论(0)
发评论
下载排行榜
