SN74ACT7881,pdf1024 X 18 Clock
消耗积分:2 | 格式:rar | 大小:266 | 2010-08-19
分享资料个
A FIFO memory is a storage device that allows data to be written into and read from its array at independent data rates. The SN74ACT7881 is organized as 1024 × 18 bits. The SN74ACT7881 processes data at rates up to 67 MHz and access times of 11 ns in a bit-parallel format. Data outputs are noninverting with respect to the data inputs. Expansion is accomplished easily in both word width and word depth.
The SN74ACT7881 has normal input-bus to output-bus asynchronous operation. The special enable circuitry adds the ability to synchronize independent reads and writes to their respective system clocks.
The SN74ACT7881 is characterized for operation from 0°C to 70°C.
评论(0)
发评论
下载排行榜
