MBI5016,pdf(16-bit Constant Cu
消耗积分:5 | 格式:rar | 大小:280 | 2010-08-21
分享资料个
MBI5016  provides  users with  great  flexibility  and  device
performance  while  using  MBI5016  in  their  LED  panel
system  design.  Users  may  adjust  the  output  current  of
MBI5016  through  an  external  resistor, Rext,  which  gives
users  flexibility  in  controlling  the  light  intensity  of  LEDs.
MBI5016  guarantees  to  endure  17V  at  the  output  port,
allowing users  to connect more LEDs  in series. The high
clock  frequency,  20  MHz,  also  satisfies  the  system
requirement of high volume data transmission.
Product Description
MBI5016, utilizing the most advanced silicon technology,
is  targeted  for  LED  panel  display.  MBI5016  contains
CMOS  shift  registers  and  latch  functions,  converting
serial input data into parallel output format. At the output
stage, sixteen regulated current sources, implemented in
Bipolar  Junction  Transistor,  were  designed  to  provide
5-90 mA constant current for driving LEDs.
评论(0)
发评论
下载排行榜
