TSB43DA42,TSB43DB42,pdf(IEEE 1
消耗积分:2 | 格式:rar | 大小:402 | 2010-08-22
分享资料个
特性
  • 1394 Features
    • Integrated 400/200/100 Mbps 2-Port PHY
    • Compliant to IEEE 1394-1995 and IEEE 1394a-2000 Standards
    • Supports Bus Manager Functions and Automatic 1394 Self-ID Verification
    • Separate Asyncchronous Ack FIFOs Decrease the Ack-Tracking Burden on External CPU
  • DTLA Encryption Support for MPEG2-DVB, DSS, and Audio Data (TSB43DA42 Only)
    • Support for up to Three Encrypted/Decrypted Streams at One Time
    • Full Ake Performed With Hardware Assist
    • Secure Method for Loading DTLA Information Using Ex-CPU Interface
  • Audio and Video Interfaces
    • Three Configurable High-Speed Data Ports for Video DataTwo Ports Configurable as Parallel or Serial One Port Serial Only
    • Two Interfaces for Audio Data (Only One Audio Stream Supported at a Time)60958 PortI2S-Style DAC Interface for PCM Data (Two Channel)
    • Pass-Through Modes for HSDI0 and HSDI1
    • Packet Insertion — Two Insertion Buffers per HSDI
    • PID Filtering (32 PID Filters per HSDI Port)
  • External CPU Interfaces
    • Motorola 68K-Style 16-Bit Asynchronous Interface (Supports External DMA Only)
    • SRAM-Like 16-Bit Asynchronous Interface (Supports External DMA Only)
    • PCI Interface (33 MHz) Compliant to PCI Specification Version 2.2 (Supports PCI Slave and Master Function)
  • Data Buffers
评论(0)
发评论
下载排行榜
