TAS5261,pdf(315-W Mono BTL Dig
消耗积分:5 | 格式:rar | 大小:938 | 2010-09-11
分享资料个
The TAS5261 is a high-performance, integrated mono digital amplifier power stage designed to drive 4- speakers with low harmonic distortion. This system requires only a simple, passive demodulation filter to deliver high-quality, high-efficiency audio amplification.
The TAS5261 has complete protection circuitry integrated on chip, safeguarding the device and speakers against fault conditions that could damage the system. These protection features are short-circuit protection, overcurrent protection, undervoltage protection, and a loss of pulse-width modulation (PWM) input signal (PWM Activity Detector).
A power-on reset (POR) circuit is used to eliminate power-supply sequencing that is normally required for most H-bridge designs.
评论(0)
发评论
下载排行榜
