EL5462 pdf datasheet (500MHz L
消耗积分:3 | 格式:rar | 大小:666 | 2008-09-21
分享资料个
The EL5462 is a current feedback amplifier with a bandwidth of 500MHz which makes this amplifier ideal for today’s high speed video and monitor applications.
With a supply current of just 1.5mA per amplifier and the ability to run from a single supply voltage from 5V to 12V, the EL5462 is also ideal for handheld, portable or battery-powered equipment.
The EL5462 is available in a 14-pin SO package and operates over the industrial temperature range of -40°C to +85°C.
评论(0)
发评论
下载排行榜
