LT1014D-EP,pdf(Quad Precision
消耗积分:3 | 格式:rar | 大小:641 | 2010-09-17
h1654155275.3301
分享资料个
The LT1014D is a quad precision operational amplifier with 14-pin industry-standard configuration. It features low offset-voltage temperature coefficient, high gain, low supply current, and low noise.
The LT1014D can be operated with both dual ±15-V and single 5-V power supplies. The common-mode input voltage range includes ground, and the output voltage can also swing to within a few milivolts of ground. Crossover distortion is eliminated.
评论(0)
发评论
下载排行榜
