INA200,INA201,INA202,pdf(High-
消耗积分:3 | 格式:rar | 大小:554 | 2010-09-24
h1654155957.9921
分享资料个
The INA200, INA201, and INA202 are high-side current-shunt monitors with voltage output. The INA200-INA202 can sense drops across shunts at common-mode voltages from -16V to 80V. The INA200-INA202 are available with three output voltage scales: 20V/V, 50V/V, and 100V/V, with up to 500kHz bandwidth.
The INA200, INA201, and INA202 also incorporate an open-drain comparator and internal reference providing a 0.6V threshold. External dividers are used to set the current trip point. The comparator includes a latching capability, which can be made transparent by grounding (or leaving open) the RESET pin.
The INA200, INA201, and INA202 operate from a single +2.7V to +18V supply, drawing a maximum of 1800µA of supply current.
评论(0)
发评论
下载排行榜
