MAX1785 pdf datasheet
消耗积分:10 | 格式:rar | 大小:777 | 2008-09-22
分享资料个
The MAX1785 smart battery-pack controller integrates a user-programmable microcontroller core, a Coulomb-counting fuel gauge, a multichannel data-acquisition unit, and an SMBus™ v1.1-compliant master/slave interface. The 8-bit RISC microcontroller core has an integrated 32kB of user-programmable flash, which provides battery-pack designers with complete flexibity in developing fuel gauging and control algorithms. The MAX1785 is equipped with in-system debug (ISD) capability for efficient firmware development and debugging.
The MAX1785 includes a 12-bit data-acquisition unit to measure individual cell voltages, thermistor, instant current, and pack voltage. Individual cell voltage measurements with 0.5% accuracy and overcurrent protection allow the MAX1785 to eliminate a separate first-level protection IC. Internally adjustable overcurrent thresholds and delay timers provide a flexible solution.
The integrating fuel gauge module provides a typical input offset of less than 1µV and gain accuracy of better than 1% with no trimming required during pack manufacture. The MAX1785 has a wide 4V to 25V operating voltage range. The MAX1785 is available as a 38-pin TSSOP. The MAX1785 EV kit is available to assist with development.
关键特性
  • Accurate Fuel Gauge Uses V-to-F Method
  • 8-Bit RISC Microcontroller Core
  • 32kB of Program Flash
  • 512 Bytes of Data Flash
  • 776 Bytes of RAM
  • 12-Bit ADC
  • Watchdog Timer
  • In-System Debug for Firmware Debugging
  • Integrated Development Environment
  • 应用/使用
     笔记本电脑电池组
     专用电池组
     远端数据记录
    评论(1)
    发评论
    zwy9008 2017-12-19
    0 回复 举报
    是芯片技术参数吗?想看下! 收起回复
    下载排行榜
    全部1条评论
