TRF3762/TRF3762-E pdf datasheet (Integer-N PLL With integrated VCO)
TRF3762-E is a high performance, highly integrated frequency synthesizer, optimized for high performance applications. The device includes a low-noise, voltage-controlled oscillator (VCO) and an integer-N PLL. TRF3762-E integrates divide-by 1, 2, or 4 options for a more flexible output frequency range. The device is controlled through a 3-wire serial-programming-interface (SPI) interface. For power sensitive applications, the device can be powered down by the SPI interface or externally via CHIP_EN (pin 2).
The TRF3762-E offers the ability to reduce lock time when compared to the TRF3761-E device. The TRF3762-E was designed so that the external loop filter is the determining factor in the setting of lock time. Typical lock times for the TRF3762-E are less than 350ms (depending on the loop filter circuit). All other features of the TRF3762-E are identical to the TRF3761-E including superior phase noise and spurious output as well as the programming model and register mapping. The TRF3762-E is pin-to-pin compatible to the TRF3761-E.
下载资料需要登录,并消耗一定积分。
