MAX2209A,pdf (RF功率监测器,带有关断控制)
消耗积分:10 | 格式:rar | 大小:333 | 2010-10-02
分享资料个
The MAX2209A is a wideband (800MHz to 2GHz) RF power detector. It takes an RF signal from the directional coupler at the input, and outputs a DC voltage proportional to the RF peak voltage. The change in output voltage versus temperature is very repeatable from part to part and enables a lookup table based on nominal behavior, minimizing the effective detection error to less than ±0.5dB relative to room temperature.
The MAX2209A comes in a space-saving 2 x 2, 0.5mm pitch UCSP™.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
