我们正在构建这个项目,以便在有人打开冰箱时检测异常。这将有助于行业所有者跟踪温度范围。就像在给定的示例中,我们看到 Nigel 先生必须保持一定的温度范围以避免损坏药片。
让我们开始构建这个项目。
第 1 步:握住传感器,以便您可以读取上面写的 LM35。
第 2 步:在此位置,将传感器的引脚从左到右识别为 VCC、输出和接地。
请参考下图。
2) 在 Bolt Cloud 上创建产品,监控来自 LM35 的数据,并将其链接到您的 Bolt
参考下图
注意:在继续之前,您需要一个 Digital Ocean、Putty、mailgun 和 twilio 帐户。如果您不了解它们,请参阅Bolt Iot 培训中的“通过 VPS 连接传感器” 。
mkdir Anomaly_Detection;
cd Anomaly_Detection;
sudo nano sms_conf.py和sudo nano email_conf.py
SSID = 'You can find SSID in your Twilio Dashboard'
AUTH_TOKEN = 'You can find on your Twilio Dashboard'
FROM_NUMBER = 'This is the no. generated by Twilio. You can find this on your Twilio Dashboard'
TO_NUMBER = 'This is your number. Make sure you are adding +91 in beginning'
API_KEY = 'This is your Bolt Cloud account API key'
DEVICE_ID = 'This is the ID of your Bolt device'
FRAME_SIZE = 10
MUL_FACTOR = 6
MAILGUN_API_KEY = 'This is the private API key which you can find on your Mailgun Dashboard'
SANDBOX_URL= 'You can find this on your Mailgun Dashboard'
SENDER_EMAIL = 'This would be test@your SANDBOX_URL'
RECIPIENT_EMAIL = 'Enter your Email ID Here'
sudo nano anomaly_detection.py
python3 anomaly_detection.py
代码最初将开始打印以下内容。
谢谢!!
