The ADL5240 is a high performance digitally controlled variable gain amplifier operating from 100 MHz to 4000 MHz. The VGA integrates a high performance, 20 dB gain, internally matched amplifier with a 6-bit digital step attenuator (DSA) with 31.5 dB gain control range, 0.5 dB steps, and ±0.25 dB step accuracy. The attenuation of the DSA can be controlled using a serial or parallel interface.
The ADL5240 consumes just 90 mA and operates off a single supply ranging from 4.75V to 5.25V. The VGA is packaged in a thermally enhanced 5 mm × 5 mm 32-lead LFCSP, and is fully specified for operation from -40°C to +85°C. A fully populated evaluation board is available.
