TLV70033-Q1,pdf(200-mA Low-IQ
消耗积分:3 | 格式:rar | 大小:491 | 2010-10-21
分享资料个
DESCRIPTION
The TLV700xx series of low-dropout (LDO) linear regulators are low quiescent current devices with excellent line
and load transient performance. These LDOs are designed for power-sensitive applications. A precision bandgap
and error amplifier provides overall 2% accuracy. Low output noise, very high power-supply rejection ratio
(PSRR), and low dropout voltage make this series of devices ideal for most battery-operated handheld
equipment. All device versions have thermal shutdown and current limit for safety.
Furthermore, these devices are stable with an effective output capacitance of only 0.1 mF. This feature enables
the use of cost-effective capacitors that have higher bias voltages and temperature derating. The devices
regulate to specified accuracy with no output load.
The TLV700xx LDOs are available in the SOT23-5 (DDC) package.
评论(0)
发评论
下载排行榜
