DG2511/2512/2513 pdf datasheet
消耗积分:5 | 格式:rar | 大小:666 | 2008-09-28
分享资料个
The DG2511/DG2512/DG2513 are low on-resistance, single-
pole/double-throw or single-pole/single-throw monolithic
CMOS analog switch. It is designed for low voltage applications.
The DG2511/DG2512/DG2513 are ideal for portable
and battery powered equipment, requiring high performance
and efficient use of board space. In additional to the low onresistance
(1.3 Ω at 2.7 V).
The DG2511 is an SPDT and the DG2512/DG2513 are
SPST. The switch conducts equally well in both directions
when on, and blocks up to the power supply level when off.
The DG2511/DG2512/DG2513 are built on Vishay Siliconix’s
low voltage JI5L process. An epitaxial layer prevents latchup.
Break-before-make is guaranteed.
The DG2511/DG2512/DG2513 represents a breakthrough in
packaging development for analog switching products. The
miniQFN-6 package (1.2 x 1.0 mm).
As a committed partner to the community and the environment,
Vishay Siliconix manufactures this product with the
lead (Pb)-free device terminations. For analog switching
products manufactured with NiPdAu device terminations, the
lead (Pb)-free "-E4" suffix is being used as a designator.
评论(0)
发评论
下载排行榜
