BQ78412,pdf(Pb-Acid Battery St
消耗积分:5 | 格式:rar | 大小:459 | 2010-11-04
分享资料个
The bq78412 Pb-Acid Battery State-of-Charge (SoC) Indicator with Run-Time Display is a complete stand-alone battery gas-gauge solution designed for single 12V Pb-Acid batteries. The bq78412 displays remaining Run-Time-To-Empty during discharge and Percent (%) capacity during charge using a 10-LED (light-emitting diode) bar graph.
The bq78412 monitors battery voltage, current, and ambient temperature to calculate state-of-charge and determine remaining runtime-to-empty. Measured values can be recorded and tracked for later retrieval for warranty purposes.
Programmable cell models allow the bq78412 to be customized to a variety of Pb-Acid formulations and capacities.
Current measurements and Coulomb-counting for gas-gauging are also automatically performed by the bq78412.
评论(0)
发评论
下载排行榜
