BQ2060A,pdf(SBS v1.1-Compliant
消耗积分:5 | 格式:rar | 大小:832 | 2010-11-05
分享资料个
The bq2060A SBS-compliant gas gauge IC for battery pack or in-system installation maintains an accurate record of available charge in rechargeable batteries. The bq2060A monitors capacity and other critical battery parameters for NiCd, NiMH, Li-ion, and lead-acid chemistries. The bq2060A uses a voltage-to-frequency converter with automatic offset error correction for charge and discharge counting. For voltage, temperature, and current reporting, the bq2060A uses an A-to-D converter. The onboard ADC also monitors individual cell voltages in a Li-ion battery pack and allows the bq2060A to generate control signals that may be used with a pack supervisor to enhance pack safety.
The bq2060A supports the smart battery data (SBData) commands and charge-control functions.
评论(0)
发评论
下载排行榜
