给出了一种小功率步进电机驱动器的设计方法:利用串口通信将电机的速度、方向等参数传送给驱动器的CPU—SPCE062A,CPU根据相关参数,直接产生脉冲信号,并完成环分任务,最后由双H桥驱动器NJU7382完成小功率步进电机的整步或半步驱动。
- Abstract:
- A method of low power step motor driver is given. The parameter of speed and direction of rotation are sent to the CPU(SPCE062A) of driver through the serial communication, then CPU produce the pulse directly and complete the task of loop-distribute,at last,it makes the step motor work with full step or half step by the dual H-bridge chip NJU7382.
