ML87V21071 pdf datasheet (Vide
消耗积分:5 | 格式:rar | 大小:666 | 2008-10-29
分享资料个
The ML87V21071, which comprises a frame memory and signal processing and memory control logic circuits, has achieved motion-adaptive 3D noise reduction. To perform noise reduction with afterimage suppression, the ML87V21071 also enables noise reduction using the edge-adaptive 2D noise reduction filter. Each noise reduction function allows setting an automatic mode. In automatic mode, noise of a vertical blanking period and a valid data period is detected to reduce noise according to the noise status from which the noise reduction setting value is detected. The ML87V21071 also has a cross-color cancellation function that uses the motion-adaptive 3D comb filter method that removes cross colors occurring at two-dimensional YC separation in the NTSC/PAL system. Since the same format as the input can be selected for output, noise reduction can easily be achieved by inserting the IC into the conventional system.
评论(0)
发评论
下载排行榜
