MC14069/MC14069B pdf datahseet
消耗积分:5 | 格式:rar | 大小:333 | 2008-11-07
分享资料个
The MC14069UB hex inverter is constructed with MOS P–channel
and N–channel enhancement mode devices in a single monolithic
structure. These inverters find primary use where low power
dissipation and/or high noise immunity is desired. Each of the six
inverters is a single stage to minimize propagation delays.
• Supply Voltage Range = 3.0 Vdc to 18 Vdc
• Capable of Driving Two Low–Power TTL Loads or One Low–Power
Schottky TTL Load Over the Rated Temperature Range
• Triple Diode Protection on All Inputs
• Pin–for–Pin Replacement for CD4069UB
• Meets JEDEC UB Specifications
评论(0)
发评论
下载排行榜
