RT8058 pdf datasheet (1MHz, 2A
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-12
分享资料个
The RT8058 is a current mode PWM step-down converter.
The chip is ideal for fixed frequency and low ripple
applications over full range of load conditions. Its input
voltage range is from 2.6V to 5.5V with a constant 1MHz
switching frequency that allows it to adopt tiny, low cost
capacitors and inductors with 2mm or less in height making
it ideal for single-cell Li-lon/polymer battery applications.
The low on resistance internal MOSFET can achieve high
efficiency without the need of external schottky diodes in
wide operating ranges and the output voltage is adjustable
from 0.6V to 5V that can provide up to 2A load current.
The RT8058 operates at 100% duty cycle for low dropout
operation that extends battery life in portable devices.
The RT8058 is available in a WQFN-16L 3x3 package.
评论(0)
发评论
下载排行榜
