DRV1101 pdf datasheet (HIGH PO
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-18
Petc
分享资料个
DESCRIPTION
The DRV1101 is fixed gain differential line driver
designed for very low distortion operation when driving
DSL line transformers. It is designed for use as the
upstream line driver for ADSL G.Lite, and as both
upstream and downstream line drivers in CAP systems.
Operating on a single 5V supply, the DRV1101
can supply up to 230mA peak output current. The
output voltage can swing up to 9.5Vp-p on a single 5V
supply. In ADSL G.Lite applications, DRV1101 can
supply up to 10dBm average line power with a crest
factor of 5.3 for a peak line power delivered of
approximately 25dBm. It is packaged in a 8-lead
SOIC.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
