TJA1021 pdf datasheet (LIN 2.0
消耗积分:10 | 格式:rar | 大小:333 | 2008-12-20
overheat
分享资料个
The TJA1021 is the interface between the Local Interconnect Network (LIN) master/slave
protocol controller and the physical bus in a LIN. It is primarily intended for in-vehicle
sub-networks using baud rates from 1 kBd up to 20 kBd and is LIN 2.0/SAE J2602
compliant. The TJA1021 is pin-to-pin compatible with the TJA1020 and improved on
ElectroStatic Discharge (ESD).
The transmit data stream of the protocol controller at the transmit data input (TXD) is
converted by the TJA1021 into a bus signal with optimized slew rate and wave shaping to
minimize ElectroMagnetic Emission (EME). The LIN bus output pin is pulled HIGH via an
internal termination resistor. For a master application an external resistor in series with a
diode should be connected between pin INH or pin VBAT and pin LIN. The receiver detects
the data stream at the LIN bus input pin and transfers it via pin RXD to the microcontroller.
In sleep mode the power consumption of the TJA1021 is very low. In failure modes the
power consumption is reduced to a minimum.
评论(0)
发评论
下载排行榜
