DP83815 pdf datasheet (10/100
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-25
分享资料个
DP83815 is a single-chip 10/100 Mb/s Ethernet Controller
for the PCI bus. It is targeted at low-cost, high volume PC
mother boards, adapter cards, and embedded systems.
The DP83815 fully implements the V2.2 33 MHz PCI bus
interface for host communications with power management
support. Packet descriptors and data are transferred via
bus-mastering, reducing the burden on the host CPU. The
DP83815 can support full duplex 10/100 Mb/s transmission
and reception, with minimum interframe gap.
The DP83815 device is an integration of an enhanced
version of the National Semiconductor PCI MAC/BIU
(Media Access Controller/Bus Interface Unit) and a 3.3V
CMOS physical layer interface.
评论(0)
发评论
下载排行榜
