HI5800 pdf datasheet (12-Bit,
消耗积分:3 | 格式:rar | 大小:333 | 2009-01-08
王平
分享资料个
The HI5800 is a monolithic, 12-bit, sampling Analog-to-
Digital Converter fabricated in the HBC10 BiCMOS process.
It is a complete subsystem containing a sample and hold
amplifier, voltage reference, two-step subranging A/D, error
correction, control logic, and timing generator. The HI5800 is
designed for high speed applications where wide bandwidth,
accuracy and low distortion are essential.
Related Literature
• Technical Brief TB363 “Guidelines for Handling and
Processing Moisture Sensitive Surface Mount Devices
(SMDs)”
评论(0)
发评论
下载排行榜
