ISL90842 pdf datasheet (Quad D
消耗积分:3 | 格式:rar | 大小:555 | 2009-01-10
李静
分享资料个
Low Noise, Low Power I2C® Bus, 256 Taps
The ISL90842 integrates four digitally controlled
potentiometers (DCP) configured as variable resistors on a
monolithic CMOS integrated circuit.
The digitally controlled potentiometers are implemented with
a combination of resistor elements and CMOS switches. The
position of the wipers are controlled by the user through the
I2C bus interface. Each potentiometer has an associated
Wiper Register (WR) that can be directly written to and read
by the user. The contents of the WR controls the position of
the wiper.
The DCPs can be used as two-terminal variable resistors in
a wide variety of applications including control, parameter
adjustments, and signal processing.
评论(0)
发评论
下载排行榜
