AK2573/AK2573A pdf datasheet (
消耗积分:5 | 格式:rar | 大小:443 | 2009-01-16
生龙活虎3
分享资料个
The AK2573A is a 1chip LDD (Laser Diode Driver) and an APC (Auto Power Control) for laser direct modulation application. It contains up to 156M LDD, programmable duty adjustment, BIAS and modulation currents, a digital feedback circuit, BIAS and modulation current monitors, failure alarms, I2CTM interface, an EEPROM for storing LD characteristics
and user information, and TXFAULT detection for SFP application. The AK2573A has two APC functions;APC FF (Feed-forward) and APC FB (Feedback). APC FF supplies a programmed current in response to the temperature. APC FB provides a stable auto power
control function with an internal digital feedback algorithm.All program and operational functions can be set through the I2CTM compatible interface and stored in the on-chip EEPROM.
评论(0)
发评论
下载排行榜
