The AKD4393 is an evaluation board for AK4393, which is 96kHz sampling 24Bit A DAC. The AKD4393
includes a LPF which can add differential analog outputs from the AK4393 and also has a digital interface with AKM's wave generator using ROM data and AKM's ADC evaluation boards. Therefore, it is easy to evaluate the AK4393.
On-board differential output buffer circuit On-board clock generator BNC connector for an extemal clock input Compatible with 3types of interface
1. Direct interface with evaluation boards for AKM's AD converter (AKD539X, AKD535X)
2. Interface with a signal generator (AKD43Xx)
3. On-board CS8414 as DIR which accepts optical input.
| 文件名 | 大小 |
| 高品质DAC转换器AK4393电路.pdf | 2M |
