EL8302 pdf datasheet (500MHz R
消耗积分:2 | 格式:rar | 大小:433 | 2009-01-16
刘杰
分享资料个
The EL8302 represents a triple rail-to-rail amplifier with a -
3dB bandwidth of 500MHz and slew rate of 600V/μs.
Running off a very low supply current of 5.6mA per channel,
the EL8302 also features inputs that go to 0.15V below the
VS- rail.
The EL8302 includes a fast-acting disable/power-down
circuit. With a 25ns disable and a 200ns enable, the EL8302
is ideal for multiplexing applications.
The EL8302 is designed for a number of general purpose
video, communication, instrumentation, and industrial
applications. The EL8302 is available in an 16-pin SO and
16-pin QSOP packages and is specified for operation over
the -40°C to +85°C temperature range.
评论(0)
发评论
下载排行榜
