摘要在修正因子模糊控制方法中引入了在线插值算法,并将其应用于水箱液位控制系统中。实验结果表明:此方法能从本质上消除系统的稳态误差,明显地改善了模糊控制系统的稳态性能。 关键词模糊控制修正因子在线插值算法 Abstract In correction factor fuzzy control method an online interpolation algorithm is introduced. And it has been used in level control system of water tank. The result of experiment shows that this method eliminated steady state error of the system inherently,and improved performance of steady state of fuzzy control system. Keywords Fuzzy control Correction factor On-line interpolation algorithm
