ISL97636 pdf datasheet (8-Chan
消耗积分:3 | 格式:rar | 大小:322 | 2009-02-07
靓仔峰
分享资料个
The ISL97636 is an integrated power LED driver that controls 8 channels of LED current for LCD backlight applications. The ISL97636 is capable of driving typically 72
(8x9) pieces of 3.5V/30mA or 80 (8x10) pieces of
3.2V/20mA LEDs. The ISL97636’s contains 8 channels of
voltage controlled current sources with typical currents
matching of ±1%, which compensate for the non-uniformity
effect of forward voltages variance in the LED stacks. To
minimize the voltage headroom and power loss in the typical
multi-strings operation, the ISL97636 features a dynamic
headroom control that monitors the highest LED forward
voltage string and uses its feedback signal for output regulation.
评论(0)
发评论
下载排行榜
