MAX2393, MAX2396, MAX2400 pdf
消耗积分:3 | 格式:rar | 大小:444 | 2009-02-21
分享资料个
The MAX2390-MAX2393/MAX2396/MAX2400 (referred to as the MAX2390 family) fully integrated direct-conversion receiver ICs are designed for W-CDMA and TDSCDMA applications.
The MAX2390 family of receiver ICs have over 90dB of dynamic gain control, and typical noise figure of 2.7dB referred to LNA input. Each receiver consists of an ultra-low-current low-noise amplifier (LNA) with on-chip output matching and a two-step gain control. The zero-IF demodulator has a differential circuit topology for minimum LO leakage to receiver's input. The channel selectivity is done completely in the baseband section of the receiver with an on-chip lowpass filter. The AGC section has over 50dB of gain-control range. LO quadrature generation is done on-chip through a divide-by-2 prescaler. The DC offset cancellation in the I/Q baseband channels is done fully on-chip using a DC servo loop. To quickly correct for large DC offset transients in minimal time, very fast settling time is obtained by optimization of the DC-offset-cancellation circuit's time constant.
The MAX2390 family includes a 3-wire serial bus for configuring the different receiver modes. They also include a SHDN-bar pin for full device shutdown. The receivers are fabricated using an advanced high-frequency SiGe BiCMOS process. The ICs operate from a single +2.7V to +3.3V supply and are housed in a small 28-pin leadless QFN-EP package (5mm x 5mm).
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
