The M220Z1-L03 model is a 22 inch wide TFT-LCD module with a 4-CCFL Backlight Unit and a 30-pin 2ch-LVDS interface. This module supports 1680 x 1050 WSXGA+ (16:10 wide screen) mode and displays up to 16.7 millions colors. The inverter module for the Backlight Unit is not built in. 1.2 FEATURES - Super wide viewing angle - High contrast ratio - Fast response time - High color saturation (EBU Like Specifications) - WSXGA+ (1680 x 1050 pixels) resolution - DE (Data Enable) only mode - LVDS (Low Voltage Differential Signaling) interface
