802.11a/g MiniPCI card EWL-06X
消耗积分:3 | 格式:rar | 大小:444 | 2009-03-16
王璐
分享资料个
802.11a/g MiniPCI card with Atheros AR5006XS
chipset
Chipset Atheros AR5006XS(AR5414A)
Interface
Type Mini PCI Interface Type IIIA
Dimensions 60x45x4 mm
Weight 20g
Frequency
Band
802.11a
5.15GHz to 5.85GHz (subject to local
regulations)
802.11b
ISM band 2.400 ~ 2.484GHz (subject to local
regulations)
802.11g
regulations)
Network
Standard IEEE 802.11a,802.11b,802.11g
Number of
Channel
802.11a
*subject to local regulations
802.11b
USA and Canada – 11
Most European countries – 13
Japan – 14
France – 4
802.11g
USA and Canada – 13
Japan – 14
Spreading
802.11a
Orthogonal Frequency Division Multiplexing
(OFDM)
802.11b
Direct Sequence Spread Spectrum (DSSS)
802.11g
(OFDM)
Modulation
802.11a/g: 64 QAM, 16
QAM,QPSK, BPSK
802.11b: CCK,DQPSK,DBPSK
Data Rate
802.11a
54, 48, 36,24,18,12, 9, 6 Mbps per
channel, auto
fallback for extended range
802.11b
11,5.5, 2, 1 Mbps per channel,
auto fallback for extended range
802.11g
108, 54, 48, 36,24,18,12, 9, 6
Mbps per channel, auto
Antenna
Single antenna with 1dBi antenna
gain at 2.4GHz band and 2dBi
antenna gain at 5GHz band.
(External antenna)
Transmitted
Power
802.11a
please see the output power table
for detail.
tolerance: +/-1.5dBm
802.11b
for detail.
802.11g
for detail.
tolerance +/-1.5dBm
评论(0)
发评论
下载排行榜
