MAX17088 pdf datasheet (Intern
消耗积分:3 | 格式:rar | 大小:333 | 2009-03-23
路过秋天
分享资料个
The MAX17088 includes a high-performance, step-up regulator; a high-speed operational amplifier; a digitally adjustable VCOM calibration device with nonvolatile memory; an I²C interface; and a high-voltage, level-shifting scan driver. The device is optimized for thin-film transistor (TFT) liquid-crystal display (LCD) applications. The MAX17088 is the successor to the MAX8798.
The step-up DC-DC converter provides the regulated supply voltage for panel source driver ICs. The converter is a 1.2MHz current-mode regulator with an integrated 20V n-channel power MOSFET. The high switching frequency allows the use of ultra-small inductors and ceramic capacitors. The current-mode control architecture provides fast transient response to pulsed loads typical of source driver loads. The step-up regulator features soft-start and current limit.
The high-current operational amplifier is designed to drive the LCD backplane (VCOM). The amplifier features high output current (±150mA), fast slew rate (45V/µs), wide bandwidth (20MHz), and rail-to-rail inputs and outputs.
The programmable VCOM calibrator is externally attached to the VCOM amplifier's resistive voltage-divider and sinks a programmable current to adjust the VCOM output-voltage level. An internal 7-bit digital-to-analog converter (DAC) controls the sink current. The DAC is ratiometric relative to BOOST and is guaranteed to be monotonic over all operating conditions. The calibrator IC includes an MTP to store the desired VCOM voltage level. The 2-wire, I²C interface between the LCD panel and the programming circuit minimizes panel connector lead count and simplifies production equipment.
The high-voltage, level-shifting scan driver is designed to drive the TFT panel gate drivers. Its three outputs swing 65V (maximum) between +45V (maximum) and -25V (minimum) and can swiftly drive capacitive loads. To save power, the two complementary outputs are designed to allow charge sharing during state changes.
The MAX17088 is available in a 36-pin (6mm x 6mm), thin QFN package with a maximum thickness of 0.8mm for ultra-thin LCD panels.
评论(0)
发评论
下载排行榜
