时钟同步输入时钟DS314xx的集成电路设计
消耗积分:0 | 格式:pdf | 大小:65 KB | 2011-03-28
刘明
分享资料个
Abstract: This application note describes how Maxim's DS314xx clock-synchronization ICs can be field upgraded to accept and lock to 1Hz input clock signals. It also describes the need for a 1Hz clock monitoring function and for system software support in a few situations. With these elements in place, a system built using DS314xx devices can have standards-compliant clock-synchronization behavior with any mix of 1Hz and higher speed input clocks.
评论(0)
发评论
下载排行榜
