MAX9949和MAX9950参数测量单元
消耗积分:0 | 格式:pdf | 大小:136 KB | 2011-03-28
刘明
分享资料个
  Abstract: This application note explains the four main operating modes for the MAX9949/MAX9950 parametric measuring units (PMUs). The operating modes are: forced current/measure current (FIMI), forced current/measure voltage (FIMV), forced voltage/measure current (FVMI), and force voltage/measure voltage (FVMV). Block diagrams, equations, and tables make it easy to verify a sample setup.
  Introduction
  The MAX9949/MAX9950 are dual-channel parametric measuring units (PMUs) that have four main operating modes:
  FIMI—Forced Current/Measure Current
  FIMV—Forced Current/Measure Voltage
  FVMI—Forced Voltage/Measure Current
  FVMV—Force Voltage/Measure Voltage
评论(0)
发评论
下载排行榜
