· Full horizontal plus vertical autosync capability · Extended horizontal frequency range from 15 to 130 kHz · Comprehensive set of I2C-bus driven geometry adjustments and functions, including standby mode · Very good vertical linearity · Moire cancellation · Start-up and switch-off sequence for safe operation of all power components · X-ray protection · Power dip recognition · Flexible switched mode B+ supply function block for feedback and feed forward converter · Internally stabilized voltage reference · Drive signal for focus amplifiers with combined horizontal and vertical parabola waveforms · DC controllable inputs for Extremely High Tension (EHT) compensation · SDIP32 package.
