The MAX98502 is a high-efficiency, Class D audio amplifierthat features an integrated boost converter to delivera constant output power over a wide range of batterysupply voltages.
The boost converter operates at 2MHz, requiring only asmall (2.2FH) external inductor and capacitor.The automatic level control has a battery tracking functionthat reduces the output swing as the supply voltagedrops, preventing collapse of battery voltage.The amplifier has differential inputs and an internal fullydifferential design. The MAX98502 also features threegain settings (6dB, 15.5dB, and 20dB) that are selectablewith a logic input.The MAX98502 is available in a small, 0.5mm pitch16-bump WLP package (2.1mm x 2.1mm). It is specifiedover the extended -40NC to +85NC temperature range.
