Industrial remote monitoring systems and keep-alivecircuits spend most of their time in standby mode. Manyof these systems also depend on battery power, so powersupply effi ciency in standby state is very important tomaximize battery life. The LT®8410/-1 high effi ciencyboost converter is ideal for these systems, requiringonly 8.5μA of quiescent current in standby mode. Thedevice integrates high value (12.4M/0.4M) output feedbackresistors, signifi cantly reducing input current whenthe output is in regulation with no load. Other featuresinclude an integrated 40V switch and Schottky diode,output disconnect with current limit, built in soft-start,overvoltage protection and a wide input range, all in atiny 8-pin 2mm × 2mm DFN package.
