Abstract: The MAX2550 is a complete single-chip radio transceiver for UMTS band 1 femtocellapplications. The RD2550 reference design is based on the MAX2550 and contains all of therelevant components necessary to design and build a competitive radio solution to support thebase-station transceiver (BTS) frequency band: 1920MHz to 1980MHz (Rx) and 2110MHz to2170MHz (Tx). The RD2550 also supports downlink monitoring of surrounding macrocells. Thisenables the system to select the most suitable operating conditions (power, codes, frequencies,capacity, etc.).
