The MAX5441–MAX5444 are serial-input, voltage-output,16-bit digital-to-analog converters (DACs) in tinyμMAX® packages, 50% smaller than comparable DACsin 8-pin SOs. They operate from low +3V (MAX5443/MAX5444) or +5V (MAX5441/MAX5442) single supplies.They provide 16-bit performance (±2LSB INL and±1LSB DNL) over temperature without any adjustments.Unbuffered DAC outputs result in a low supply currentof 120μA and a low offset error of 2LSB.
