The MAX17502 high-efficiency, high-voltage, synchronousstep-down DC-DC converter operates over a 4.5Vto 60V input voltage range and is designed for a widerange of applications. The ultra-wide-input operationmakes it ideal for not only industrial control and buildingautomation, but also base stations, telecom, homeentertainment, and automotive applications. It deliversoutput currents up to 1A, at output voltages of 3.3V and5V. The output voltage is accurate within Q1.6% overtemperature. The device operates over the -40NC to+125NC industrial temperature range and is available ina tiny, 10-pin (3mm x 2mm) TDFN lead(Pb)-free packagewith an exposed pad.
